[SOLVED] not able to view orcad files in windows file explorer
abhishekgrover
Newbie level 5
Newbie level 5
I am using orcad to design pcb layouts.
When I open the capture or layout then I am able to view the schematic or layout files in the design window ,when selecting to save file or when browsing from capture or layout to load a particular file but I am unable to find the schematic and layout files when I am browsing in the particular folder using windows file explorer.
Please suggest some solutions to this problem.
Best Regards,
Abhishek Grover.
Are you sure to look in right folder?
There are some display options in Windows file explorer like "show hidden files", "show system files". You may want to try.
Please check the screen shot attached. If you click on DSN file in the project page it will display the path on top. Please check this once. And also, in orcad you can see only DSN, OPJ file for schematics. You cant see individual page in your folder where project is saved.
you might be looking in a wrong folder .
do a "*.dsn" search in the entire directory for the schematics and *.brd" (or *.max?) for the PCB.
