khuram9172
Newbie
- Joined
- Jan 10, 2025
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 21
I have simulated a circuit on the proteus to convert -22V into adjustable -3V to -16V using LM337 and Tip2955. In the simulation when I change the load, output voltage across it remain stable but when I built the hardware I am having a voltage drop of 1 to 2 volts from the adjusted voltage and also tip2955 is heating like crazy at 5A. Can someone please tell me what mistake I am making or if there is any other way to achieve this or what adjustments I can make in this circuit to achieve the desired results. In simulation it looks fine but in reality it doesn't work properly. Picture of my circuit is attached here:
