aht2000
Junior Member level 3
- Joined
- Apr 18, 2015
- Messages
- 30
- Helped
- 0
- Reputation
- 0
- Reaction score
- 2
- Trophy points
- 1,288
- Activity points
- 1,664
View attachment Noise generated from ebay 9V SMPS.pdf
I purchased a SMPS 9V module from ebay, and used it to power an STM32 microcontroller circuit and was facing difficulties with the ADC measurements. Using an oscilloscope, I found a lot of noise, and documented my findings in the attached PDF file.
I would expect that the noise be reduced when the inductor in installed on the 9V side. While the actual tests shows that it has no effect, and only was useful when installed on the ground side.
Could be noise generated from the ground side? Is this the right solution to reduce the noise from this SMPS? Can I reduce it more down to below 10mV PP to allow my ADC measurement be done correctly?
Thank you.
Thank you.
