AMSA84
Advanced Member level 2
- Joined
- Aug 24, 2010
- Messages
- 577
- Helped
- 8
- Reputation
- 16
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Iberian Peninsula
- Activity points
- 6,178
Hi guys,
First let me ask you guys a noob question: What does a Voltage-Mode controller? It controls the output voltage of the power-supply that we need? So there is no control for the current, right? And what about the Current-Mode controller? It controls the output voltage and the output current, right?
Now, I have read that in this post: https://www.edaboard.com/threads/56315/ that "In voltage-mode control ... output of the switching power supply is divided (usually using a voltage divider), is subtracted from a reference and is compensated using an error amplifier. Then the error voltage at the output of the error amplifier is compared to a sawtooth to generate the driving signal for the switching transistor. So voltage-mode control is a single loop control technique" and I agree with that. It make sense. But in this kind of operation we can't control the current, right?
Imagine that I want to design a power-supply of 12V @ 1A. We select all the components in the circuit to withstand the currents and voltages and then we implement the controller in order to set the voltage at 12V, but we need to take care in not exceeding 1A, right?
Now about the Current-Mode. In the same post that I posted the link, the Current-mode "is multi-loop control. The outer loop is a voltage-loop - so you still have the voltage being sensed and subtracted from a reference and compensated - but now the error amplifier output provides a reference for the inner current loop. In the inner loop a current in the system is sensed (by using a current sense resistor or otherwise) and compared to the reference (from the voltage loop) and this is used to generate the switching signal for the transistor. Usually the inner current loop is faster than the outer voltage loop. There are also many types of current-mode control: peak current-mode control, average current-mode control, hysteretic current mode control"
About this last statement, I don't understand what is in BOLD.So the reference from the E/A output is used as reference to the current loop? How does it work? Can someone give an example? I can't idealize it.
Now, let's imagine that I want that same power supply, but now implemented with the Current-Mode PWM controller. What will be that difference? It is the fact that the power supply will supply a constant and continuous 12V and 1A?
My DOUBT is right here. Is that, if in the Current-Mode operation the power supply will supply a continuous voltage and current. Imagine a varying load, like a PSU from a computer. The PSU utilization will vary along the time, depending of the utilization of the CPU, GPU, etc. So does not make sense to have a Current-Mode of operaton?
Imagine that I want to supply a load with that 12V @ 1A power supply (from the preview example) implemented with a Current-Mode controller, and that load needs 12V @ 500mA. I can't use the 12V @ 1A power supply implemented with a Current-Mode because it was projected with a Current-Mode controller @ 1A right? This is what I don't understand quite well yet.
Sorry for the long text.
Best regards.
Best regards.
