cupoftea
Advanced Member level 6
- Joined
- Jun 13, 2021
- Messages
- 3,103
- Helped
- 62
- Reputation
- 124
- Reaction score
- 139
- Trophy points
- 63
- Activity points
- 16,154
We have 240W isolated loads (up to eight at a time) running ultimately from a 3kW, 230vac Petrol generator.
The current supplied by the generator is not sinusoidal, but its as in the attached. Do you think
this will wear out the gennerator's bearings and overheat it?
(Specially if say eight of these 240W loads are being supplied at the same time?)
230VAC petrol generator:
The generator is fed to a Boost PFC then 240 W Two transistor forward. (up to eight of these, ie eight 240W Boost/2TF's)
The load often turns from full on to full off with a 5 second period (5 seconds ON, 5 seconds OFF).
The load switching ON or OFF is extremely sudden
(approx within 1us)
As such, we didn't do a proper boost PFC, we instead did a Fast Boost converter otherwise the boost PFC
output fell too low. (it dropped out following a no-load-to-full-load transient). Hence the non sinusoidal supply current.
In the attached , green is the generator output voltage (230VAC). Blue is the generator's supplied current.
Red is the Boost "PFC" output voltage. (obviously its not really truly PFC'ing)
Clarke 8857852 Pg3800A.3000W(Max)Petrol Generator
This versatile 3kVA generator has 2x 230V sockets making it ideal for domestic and leisure, with a 4 stroke, 5.6HP engine it provides a a reliable ...
www.powertoolsdirect.com
(approx within 1us)
