marko.severin
Newbie level 3
Greetings,
I need to design a SMPS with the following: Vin = 120-300V, Vout = 13.5V, Iout = 15A. It must be as small and as efficient as possible. Also, it does not have to be isolated and it does not require PFC.
Basically what I need is a step-down converter. I've done some basic calculations and a two-stage buck converter yields quite poor efficency, since I have to use 600V mosfets for the first stage.
So, what topology would you recommend? A LLC resonant converter seems to be a popular choice, but given the wide input voltage range, I do not believe it to be a good choice.
Thanks to all!
Thanks to all!
