But shouldn't it then be Vout = A(V+ - V-) = A(Vin - Vout*R2/(R2+Rf)) = Vin*(R2+Rf)/R2.
If R2 = Rf and Vin = 5V, then Vout = 5*2 = 10V.
Now V+ = Vin = 5V, but V- = 10/2 = 5V,
so Vout = A(5 - 5) = 0? But it's not 0. Why?
How do you know? It's not correct.I just know that, when V+ - V- = 0, the output stays at 10V,
f[/img]
but when V+ - V- < 0, the is pulled down to 10V, and when V+ - V- > 0, the output is pulled up to 10V.
I would be grateful if someone could explain me why that happens.
And the circuit is this, if anyone can't see it. (I can see it in my first post.)
Hi NonBio,
What you are making thinking in that way is equivalent to consider a discrete-time system, or to insert a pure delay at the output of the amplifier.
In reality, we are in continuous time and the response of the amplifier has some rise time (it is not instantaneous). Between what you call "previous" and "new" (or "ith-1" and "ith" instants), the output changes continuously and (if some stability conditions exist) the equilibrium poit is reached after a transient during which the output changes continuously and more or less gracefully.
If you do have a delay and the response of the amplifier is instantaneous (no rise time, or rise time much lower than the delay), then what you said takes place and the system is unstable.
Regards
Z
And for a circuit with Rf = R2, A = 10000, Vin = 5V, Supply = +-12V, I would get Vout varying between 9.9976 and 10.0024V, producing 10V on average.
The variation numbers suggest that you did a calculation with open loop gain. It's basically wrong.
You won't expect any variation as long there are no external disturbances causing it, independent of the amplifier open loop gain A. In connection with zorro's visual explanation: The nature of the time continuous, linear system results in a stable steady state for all involved circuit nodes. Only electronic noise is causing some very small fluctuations.
For simplicity, let us assume that you are talking about the output response to an input step. There may be an overshoot or even a short decaying oscillation, according to amplifier frequency characteristic and also large signal behaviour. That's still very different from the previously assumed permanent output voltage variation. But with respective frequency compensation, the settling can be truely monotonic.So the output goes from 0 to 10V without any oscillations and then stays at 10V?
As already said, there's electronic noise. You can expect nV, uV or more, depending on amplifier and measurent bandwidth. But it's caused by a random process, nothing like an oscillatory variation of output voltage as previously assumed.But there should be a tiny variation of a magnitude of fV or smth?
