boylesg
- Joined
- Jul 15, 2012
- Messages
- 1,023
- Helped
- 5
- Reputation
- 10
- Reaction score
- 6
- Trophy points
- 1,318
- Location
- Epping, Victoria, Australia
- Activity points
- 11,697
How do I make this work in multisim?
I have this circuit:
Virtual ground of of Vcc(16V) / 2 = 8V.
There is a function generator off the top edge of the image feeding a sine wave (o.5V peak, 10kHz) into my opamp.
With both the signal generator and the 4 channel scope grounded, this is what I get. The sine wave is the input signal from the function generator. But all I get from my opamp is a flat line.
I tried grounding the the function generator to my virtual ground of 8V.
The sine wave input signal goes off the top edge of the scope unless I put in a negative offset to move it down into view.
And the output of my opamp seems to be a clipped triangle wave, oscillating about 8V, instead of an identical sine wave of large amplitude.
I don't get it. How do you implement a non-inverting amplifier with a Vcc/GND
My non-inverting opamp works terrifically if I make the supply 16V/-16V with the standard configuration straight from the opamp datasheet.
Is this just an artifact of multisim to be ignored?
