Z
zenerbjt
Dear Engineers,
We are using 10Kw BLDCs fed by 3 phase inverters. We wish to scope the current waveform in the battery supply cable to the inverter. We have selected the MLX91209 current sensor since it gives a non-invasive solution, and our current peaks will be up to some 400A. One must simply mount the MLX91209 into a gap in a ring torroid, and then run the conductor through that same torroid. The MLX91209 then gives a voltage output proportional to the current. It has the same bandwidth as a current sense transformer, near enough.
https://www.melexis.com/en/product/MLX91209/250kHz-Programmable-Hall-Effect-Current-Sensor
However, the Melexis website doesn’t tell how we can get hold of the SUPRA 50 SP ferromagnetic cores for this useage.
Do you know how much these cost? We don’t yet have a reply from MagLab, the named manufacturer.
www.maglab.ch
www.maglab.ch
