johan.o
Newbie level 1
Hello,
(This is my first post here. )
I have built a DCM Flyback for 400 VDC to 750 VDC input voltage.
With a output of 15V/2A.
Actually i followed this application note (https://www.st.com/stonline/products/literature/an/13127.pdf) when i built it.
One of the bigger problems i had was that the output was quite noisy so i putted
a extra LC filter (30µH/ 1000µF) on the output. That did allot!
I also placed (two 2,2nF serial connected to handle the voltage) Y1 Capacitor
between the output ground and the primary ground, to couple back capacitive coupled noise currents. That also did some to help.
But still there is some high frequency noise at the output that seem to come from
the primary side oscillations between the leakage inductance and C_cs, and also a ringing frequency that seem to come from when the transistor turns on and discharge the C_cs [ESBT].
Anyone have any tips? Perhaps i would need a screen in my transformer to stop
capacitive coupling.. i am quite frustrated so any tips would be real nice.
I am thankful for any help.
