blapcb
Full Member level 3
- Joined
- Jan 7, 2007
- Messages
- 188
- Helped
- 2
- Reputation
- 4
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Planet earth (most of the time)
- Activity points
- 2,766
I have a 3.3v rail and several boards that are working basically fine with the same power section. The LDO is MIC5209 (schema/use as per the data sheet). I have been experiencing interference on some other communication lines (SPI), and put a scope to the 3.3v rail. To my horror, I discovered a lot (is it a lot?) of spikes/noise which get severely aggravated when a RS232 cable/device is connected (I used MAX3232 line drivers).
See attached images.
My question is, how much AC should there be on such a rail? Is it normal? If not, how do I reduce/eliminate it?
