M.Sigurd
Hello,
I've got a problem with noise in my photodiode transimpedance amplifier circuit. I've looked around on this forum and on the web but couldn't find something useful so here I go...
I need to detect a moving ball passing through a collimated IR laser beam. My photodiode circuit should detect the reflection of the ball. The reflected pulse width varies between 5 and 50us and is of low power (2mW laser reflected 1 meter away...). My circuit is the following :
The only difference is I'm reverse-biasing my photodiode (Vishay bpv22nf) with -15V to reduce diode capacitance.
Rf is 820kΩ, Cf is approx 0.5pF, Cdiode is approx 20pF. I'm using a OPA606 as transimpedance amplifier on a dual -15V/15V supply. I'm also using bypass capacitors where needed. Everything is mounted on a standard breadboard.
Now to the problem : I'm getting some significant noise with V_noise_rms ≈ 8mV and frequency of 100KHz when ambient light shines on the photodiode (indoor, normal conditions...). This noise goes away if I cover the photodiode. And I can't filter it because it is in the frequency range in need to detect...
The problem does not come from the amplifier oscillating : the feedback capacitance Cf is high enough. Could Johnson noise in my photodiode / feedback resistor create such a high noise voltage at such a frequency ? Do you have some ideas ?
I would be very grateful if somebody that worked on a similar problem could shine some light in my direction :wink:
Mike
PS : I'll attach some scope screenshots tomorrow !
Mike
