gunturikishore
Full Member level 2
- Joined
- Aug 19, 2004
- Messages
- 146
- Helped
- 13
- Reputation
- 26
- Reaction score
- 6
- Trophy points
- 1,298
- Location
- INDIA GANDHINAGAR
- Activity points
- 1,363
Hi everybody,
I am trying to do the Noise analysis on the transistor amplifier with active load on the CS configuration. It gives a Noise Figure of 8 to 9 dB Noise Figure on .18 u M technology when done with Noise analysis on ic5.0. I have no sufficient data to compare this result with any other. Can any body tell me about the correctness of the result??
Similarly I tried to find the Flicker Noise that is generated through Noise summmary. But it shows 0 Flicker Noise. I tried to find the Flicker Noise parameters
in the model Library file but it does not have any of the NOIA, NOIB and NOIC. Can anybody give me the typical values of these parameters for a TSMC .18u M process???
