Noise analysis in Cadence
You simply choose the noise analysis tab from ADE, specify the frequency range over which the analysis is done .You then specify the noise source and then run the analysis.
    raduga_in
You need to add a voltage source and derive input-referred noise.
What is exactally the type of simulation: is it a NOISE simulation or a PNOISE simulation?
I think that is the NOISE simulation,but what is the ouput noise and input noise ?
I used NOISE. You can try the options in the settings.
    raduga_in
I ask about the source which should added in the schematic. And, what is the input and output sources?
