Node voltages` annotation problem
ed2000
Member level 3
Member level 3
At annotation of either Operating Points or Node voltages in Virtuoso Schematic window (from IC5) I see all requested ones, but unfortunately they appear with many digit accuracy (for example 13 digits after the decimal point). Such schematics are quite inconvenient to analyze.
How can I correct this situation? May be I should use some variable set in .cdsinit or .cdsenv files?
Thanks for any relevant information .....
I got the same problem. Anybody know the solution? Thank you in advance.
