dkace
Full Member level 6
node is floating
Hi!
I have this f**** problem with OrCAD! I try to make a very simple circuit: a 5Vdc , a resistance a diode a resistance and ground. I create netlist file and I run spice. Then I get this mesage: Nodexxxx is floating, node xxxx is floating , node xxxxx is floating, ground is floating.
As you understood everything is on the air according to OrCAD! I double checked the devices and the nodes, I placed nodes at the connection points, but nothing.
What is the problem? Is it something with ground? Can anyone give me a tip on this?
Thanks,
D.
Hi!
Thanks,
D.
