No of bits necessary for the expression
sun_ray
Advanced Member level 3
How many bits ore necessary for L
L=MN + PQ + 2T
where M,N,Q,T are 16 bits and P is 8 bits.
L will need 33 Bits (Assuming they are unsigned numbers.)
L (bits) = Max ( 32bits , 24bits , 17bits ) + 1 (for carry)
Regards,
-Elecrom
Regards,
-Elecrom
Can you please explain how you arrived this? How one carry will be sufficient?
Regards
Signed or unsigned? Will make a difference for the multiplies.
Signed requires less bits, so the number of bits given by #2 is the required number of bits.
Using a slightly different set of bit widths so it's easy to calculate stuff....
L=MN + PQ + 2T
where M,N,Q,T are 4 bits and P is 2 bits.
M*N is (4-bit)*(4-bit) unsigned the biggest 4-bit number is 15 (i.e. 0b1111) and 15*15 = 225 = 0xE1 (an 8-bit value) so multiplication adds the bit widths up...
therefore P*Q = (4-bit)*(2-bit) = 6-bit (i.e. 15*3)
multiplication by 2 is a shift in binary so 2*T is 5-bit. (i.e. 2*15)
When summing the total can exceed the maximum value of 0xFF, e.g. 225+45+30=300 (a 17-bit number, 0x12C)
So in this case L must be 17-bits.
L=MN + PQ + 2T
Unsigned:
M= 16 bits, N = 16 bits therfore MxN = 32 bits.
P = 8 bits, Q = 16 bits, therfore PxQ = 24 bits.
T = 16 bits, therfore 2 x T = 17 bits.
adding a 17 bit value to a 24 bit value give max a 25 bit value (one carry bit on a 24 bit value)
adding a 25 bit value to a 32 bit value gives max a 33 bit value (one carry bit on a 32 bit value)
Klaus
In order to have a visible illustration of what we are talking about...
#include <stdio.h>
void xbits(unsigned long long x){
	unsigned long long m = 1ull << (sizeof(m)*8-1);
	while(m){
		putchar((x & m) ? '1':'0');
		m>>=1;
int main(void){
	unsigned long long m,n,p,q,t,r;
	m = n = t = q = 0xffff;
	p = 0xff;
	//r = (unsigned long long)-1;
	//printf("sizeof(r) == %u, r=%llx\n",sizeof r,r);
	r = m*n + p*q + 2*t;
	printf("%llx = ",r);
	xbits(r);
	return 0;
results printed:
100feff00 = 0000000000000000000000000000000100000000111111101111111100000000
33 bits max value (or 32 bits + 1 extra bit)
You need to be careful which language you use to write the expression as they all have different rules for width determination. T^he only reason you will get 33 bits is because the '2' in 2T is by default a 32-bit number.
