X
Xenon02
![Newbie level 1](/styles/images/ranks/alevel1.gif)
Hello !
I have a problem because I can't use yosys to sythesize this code. Whenever I try to do it this appears :
I don't know where are the latches in my code
Here is the code :
Can someone help me with this ?
Here is the code :
`include "definictions.vh"
module exe_unit_w31 (i_oper, i_argA, i_argB, i_clk, i_rsn, o_status, o_result);
input logic [`OPER_BITS-1:0] i_oper;
input logic [`BITS-1:0] i_argA, i_argB;
input logic i_clk;
input logic i_rsn;
output logic [3:0] o_status;
output logic [`BITS-1:0] o_result;
logic [`BITS-1:0] s_argA, s_argB;
logic [`BITS-1:0] s_oper;
logic [`BITS-1:0] s_y_sub;
logic [`BITS-1:0] s_y_cmp;
logic [`BITS-1:0] s_y_to0;
logic [`BITS-1:0] s_y_ZM2U2;
logic s_carry_sub;
logic s_err_to0;
logic s_err_ZM2U2;
logic sign3;
sub sub_exe (.i_a(s_argA), .i_b(s_argB), .o_y(s_y_sub), .o_carry(s_carry_sub));
cmp cmp_exe (.i_a(s_argA), .i_b(s_argB), .o_y(s_y_cmp));
to0 to0_exe (.i_a(s_argA), .i_b(s_argB), .o_y(s_y_to0), .o_err(s_err_to0));
ZM2U2 ZM2U2_exe (.i_a(s_argA), .o_y(s_y_ZM2U2), .o_err(s_err_ZM2U2));
integer ones;
integer i;
always_ff @(posedge i_clk)
begin
if(!i_rsn)
begin
s_oper <= '0;
s_argA <= '0;
s_argB <= '0;
end
else
begin
s_oper <= i_oper;
s_argA <= i_argA;
s_argB <= i_argB;
end
end
always_comb
begin
o_status = '0;
o_result = '0;
s_y_cmp = '0;
s_y_sub = '0;
s_y_to0 = '0;
s_y_ZM2U2 = '0;
s_oper = '0;
sign3 = '0;
s_carry_sub ='0;
s_err_to0 ='0;
s_err_ZM2U2 = '0;
case(s_oper)
`SUBTRACT:
begin
o_result = s_y_sub;
o_status[3] = 0;
end
`COMPARE:
begin
o_result = s_y_cmp;
o_status[3] = 0;
end
`CHANGE:
begin
o_result = s_y_to0;
if(s_err_to0)
o_status[3] = 1;
end
`CONVERSION:
begin
o_result = s_y_ZM2U2;
if(s_err_ZM2U2)
o_status[3] = 1;
end
default:
begin
o_result = '0;
o_status = 4'b1000;
end
endcase
for(int i = 0; i<`BITS ;i++)
begin
if(i ==`BITS-1)
begin
sign3 = o_result;
end
end
//NEG
if(i_oper!= 'd0)
begin
if(sign3 == 1)
begin
o_status[2] = 1;
end
end
else
begin
if(s_carry_sub == 1)
o_status[2] = 1;
else
begin
if(sign3 == 1)
begin
o_status[2] = 1;
end
end
end
//EVEN
ones = 0;
for(i = `BITS-1; i>=0; i = i-1)
begin
if(o_result == 1)
ones = ones + 1;
end
if(!(ones % 2))
o_status[1] = 1;
//ONES
if(ones == `BITS)
o_status[0] = 1;
end
endmodule
