Lucast85
Member level 3
Hello people,
I use a differential OPAMP that is AD8220. The gain I need is 1 so I not use an external Rg resistor and i must leave Rg pins disconnected.
In PCB design, this can lead to have some high frequencies disturbances on this pin? It's better to put some capacitors between Rg pins and gnd ? If yes, what value?
Thank you!!
Thank you!!
