[SOLVED] NMOS transistor, question about Vgs
Pictou
Member level 1
Member level 1
Hello,
I would like to know what happens to a NMOS transistor when Vgs < 0. My problem is that in one of my schematic Vgs = -1.3 V. Will it break?
I tried to find the answer on the internet but nothing about Vgs < 0 for a NMOS (or Vgs > 0 for a PMOS)
On the forum, people talked about Tsividis book, but all links were dead.
Thank you for your help.
@Pictou: If Source & Body are at same potential,say Ground.
Then if Vgs > 0, NMOS operates normally, with a channel formed between Source & Drain in inversion.
If Vgs < 0, NMOS will be in accumulation & has no channel between Source & Drain. It will not conduct & all,it will be in cut-off but it shouldn't break-down.
If you make Vgs <<< 0,it reaches reverse-bias breakdown between Source(n) & Body(p)
Reactions: Pictou
    Pictou
Thank you very much for your help. I'll look for reverse-bias breakdown on google to learn more.
There is just something I don't understand, if source and body are connected at the same potential, why would they be in reverse-bias breakdown as they are connected to each other?
I'm not really familiar with these phenomena, can you advise me a book that could teach me this?
Thank you again.
@Pictou: The post#2 that i posted was for a simple MOSFET with no Zener diode.
But commercial MOSFETs usually have a big and powerful zener diode that will clamp the voltage and cause a lot of heat when it avalanches. The zener diode can also conduct a high current when it is forward-biased by the drain-source voltage going reversed.But even Zener Diode will only "absorb" it to an extent
"Operation & Modelling of MOS Transistor"Tsividis is very good.You were saying links are dead.It is available on Scribd for free
Reactions: Pictou
    Pictou
Thank you for your help and the Scribd website, I didn't even know its existence. I will mark this subject as solved.
