NiMH battery charger - need some explanation
BABESH
Full Member level 2
Full Member level 2
NiMH battery cahrger
I saw from datasheet of battery manufacturer that NiMH battery can be left
un terminated with charge rate of C/20, for ever.
Will this current charge the battery pack?
After what time will the battery be fully charged?
thanks in advance.
--Babesh
can any battery expert through some light on to this.
--thx.
If the battery is completely discharged then at C/20 it will take 20 hours plus 40% more for losses. The total time to make the battery fully charged is 28 hours.
Guru,
Thanks a lot, it gave some hope for me abt this method of charging.
If battery Capacity is say 4200mAH, then c/20 is 210mAmp.
so (4200/210)*1.4=28Hours, is this equation holds good?
Then few sites are giving that factor as 1.6.
why is that factor...
thx
Babesh
Re: NiMH battery cahrger
Energizer shows that a high current charge at a C rate makes a Ni-MH cell fully charged at 110% of its capacity.
A C/10 rate makes a cell fully charged at 140% of its capacity.
Maybe C/20 needs 150%.
Guru,
Your data is supporting to equation.
Thanks a lot for proving me with data,
Now i will try waiting for 33 hours to charge the batteries.
Thanks
--Babesh.
