Ahmed Abd El Wahab
Hi all,
I'm a bit new in analog design. I'm currently working on a Low power Voltage Reference (Band-Gap) circuit on Cadence.
I'm working from a paper introducing some interesting architectures for that. The problem I'm facing is this structure uses 130-nm technology devices called NHV - NHVNATIVE mos transistors.
I have tried to find any info about these devices ,but found nothing.
hint:
- If any one could even tell what is the PDK (Design kit) in which these devices are found would definately help.
- you will find the paper I'm using attached below
hint:
