Your schematic shows no filter, it is simply a voltage limiter consisting of R 65 and CR 11 (a Zener diode). The capacitor is not necessary. If it might filter anything then one will need to know the Vin source impedance.
Yes Jiripolivka is right. The zener diode is sometimes used as a regulator. Then the capacitor in your circuit is only for stabilising the source in order to avoid voltage drops.
