Re: newbie's confusion
Regarding the 5v, the lcd pin3 shares the same rail as the pic chip.
However the +5v to the lcd backlight at the right hand side is not what I would do.
If its a standard black on green display you do not actually need the b/l, but if you do want it on, around 4v is more suitable so use a dropper resistor - try 100ohms but you might need two use 2x 220ohm in parallel to increase the wattage of the resistor.
Depending on the backlight it could take 50 -100ma,
Yes, you can add you own code at the loop stage.
Not sure about q 3/4 as that page takes a fair bit of following - I don't like complicated things - have just sent someone some starter lcd code - have pm'ed you a copy - its for the 16f628A but am just doing the same for the 16F690 for someone else - let me know if your need it changing for a particular chip if its seems easier to use to you than that mikroe stuff.
