cfiiman
Newbie level 3
Hey guys,
I am pulling my hair out chasing what I thought was a battery issue but finally I found out that it wasnt. Here is my issue, I'm trying to run a blinking red 5 mm led i bought at Radioshack off of a 3 volt battery. The thing is I have got it working perfectly except for one annoying thing, and in just stumped and have no idea why. I have the blinking led soldered to a micro slide switch then wired to coin battery holder. The first time I turn it on it works fantastic, then I turn it off. Sometimes it will work again and again for a few minutes, but 100% of the time whether it is right after I turn it off, or after letting it sit in the off position for a few seconds when I switch it back on the light will not come on. Sometimes it will take about 10 or 15 seconds and then very faintly start blinking and gradually after about 10 seconds or so will flash at normal brightness, but most of the time it will just not flash at all. Then I pop the battery wait a few seconds and it will work again. I thought I just had a bad connection but after redoing it at least 10 times and my connections are perfect every time, I reLize something is just not right, maybe with the way I'm trying to do it? Why in the world will it work fine at first after installing the battery, but not after it sits until popping out the battery again???? Please help, Im embarrassed about how many hours I have in chAsing this problem, thanks guys.
