new to Pic Basic Start help plz
janosandi
Full Member level 4
Full Member level 4
new to Pic Basic Need help plz
hello guys
what's wrong with this simple code?
as i guess it must keep at label "circoff" until portc.1 = 0 right ?
its not & jump to mainloop always
circoff:
     if PORTC.1 = 0 then
     gosub   mainloop
     goto circoff
     endif
thx for help
Re: new to Pic Basic Need help plz
Hello Janosandi,
Of course you should set the fuse-bits and config everything at header before anything else. You would add these below lines to your code lines:
TRISC.1=1           ;Set the C.1 as an input pin
Definitely, a pull-up resistor should be ( you've set this pin as low active!) on C.1
And if you don't mind share your mainloop segment here.
