Values are ok for a led current of about 1 mA may be a little small.
But the Diode in parallel with the led will never conduct so I think it is useless.
What is your purpose in including it ? protection ? balancing current?
i connected without diode there & so many times it was damaged
If the diode is not a good one, connect a 100K resistor (0.25W will do) across the LED so let it drain away.
betwixt has a very good point here.Using two resistors means the circuit can be connected either way to the AC with less risk of injury.
If you just use resistors with no diode, it WILL be damaged, most LEDS can only withstand about 5V in reverse direction so 230V RMS (about 325V peak) is a bit much for them!
With a single diode in series, no matter where you put it in the chain of components, it should work, the diode will not pass current in the reverse direction except for leakage. If the diode is not a good one, connect a 100K resistor (0.25W will do) across the LED so let it drain away. If you want to keep the resistor solution, it will work better if you use a bridge rectifier with the LED across it's output, you don't need a capacitor as well. This lets the LED light on both positive and negative AC cycles so it will appear brighter and have less flicker.
Whatever you do, please be extremely careful with 230V AC. It is more than enough to kill you and you don't get a second chance.....
Brian.
The drawback to an anti-parallel diode is it doubles the heat dissipation without giving extra brightness. If that's what is desired, a bridge rectifier with the LED across it's output will double the brightness without adding to the heat being produced.
Brian.
