Net Names are not shown in UMC 018 Design Kit!
zora
Newbie level 3
Newbie level 3
Net Names are not shown!
Hi everybody,
I'm running msfb.exe (5.1.41) with the UMC 018 Design Kit.
Everything goes well but unfortunately net names (net021,net022,etc.) are not shown on the schematic. So, I can't watch my plots clearly.
I've tried Display Options and CDF configuration but nothing changed.
Thanks in advance
Bora
Re: Net Names are not shown!
zora said:
Hi everybody,
Thanks in advance
Bora
there is an option under ADE that you can annotate net names. (or display net name) in the "result" tab.
Thank you very much...
There are property texts which you can add to symbols,
which would annotate the name when told to. But you
have to explicitly add them, your PDK provider may have
not. And few people bother, at the higher levels. But you
could.
If you select and property-edit a wire it will tell you the
net name as Cadence Composer sees it; hopefully your
netlister uses schematic-derived names and not some
bogus renumbering.
