House_Cat said:It depends on how much current you need. For low current applications, there are many ways to invert the voltage with switched capacitors:
https://www.aaroncake.net/circuits/vinvertr.htm
If you need high current, you are going to have to use a more complex approach. You will need to use a switched mode power supply using an inductor or transformer. You will have to convert the +5v to AC, boost the voltage to account for circuit losses, then regulate it back to -5vdc. If you need high current, how much do you need? Your requirements will dictate the best approach.
