Negative Voltage from DAC0808
theone_in_themoon
Junior Member level 3
Lahore Pakistan
10 pin dac0808 diagram
Hullo
I am using DAC0808 LCN to produce audio by playing WAV files. I am unable to generate negative voltage from it. Is there any way in which i can do it or will i have to use op-amps as adders etc. to get negative voltages ???
Refering to the statement in the start of Page:10 of datasheet of DAC0808, where it states:
"Bipolar input signals may be handled by connecting
R14 to a positive reference voltage equal to the peak
positive input level at pin 15."
This statement appers quite vague to me but I think there must be way to generate negative voltage by considering the input byte as a signed one (MSB for sign and rest for data).
Please help me with any diagram or a more clear statement about how to achive this goal.
Thankyou in advance,
Regards
dac0808+wav
You can try to remove dc component from the DAC output by adding a capacitor in series with the output. What you generate is an audio signal so after capacitor you will have a +/- signal ..
