pseudockb
Member level 5
capacitor negative resistance
I know this is very fundamental but I could not grasp it correctly. The circuit in the left shows a positive resistor while the one at the right shows a negative resistor. Here's my analysis on the positive resistor.
Assuming from S1 is on from 0 to T/2 but off from T/2 to T,
S2 is off from 0 to T/2 but on from T/2 to T.
V1 is the voltage at the left port while V2 is the voltage at the right port.
The current i1 from V1 to V2 is then given by
C[V(T/2)-V(0)]/T = C[(V1-V2)-0]/T
As such, we get the equivelent resistance of T/C
Similarly, when I performed the same analysis on the right hand side circuit, I got:
i1=C[V(T/2)-V(0)]/T = C[V1-(-V2)]/T
I do not understand how does this circuit give a negative resistance value? Is my analysis correct? Thanks
