Negative Resistance Circuit (NRC) for HF
pumanba2
Newbie level 3
Newbie level 3
Could anybody recommend me some Negative Resistance Circuits (CMOS) for high frequencies applications?
I'm interested in pure negative resistance independent from frequency for a wide band (several GHz).
I would be very thankful!
(except common cross-coupled mos)
Hi
Negative resistance can easily be harvested by oscillators ( positive feedback circuits ) or perhaps via an op amp with some simple additional things .
Best Wishes
Goldsmith
Hi
For "several GHz" ???
Means what? Negative resistance can be implemented by transistors in a wideband positive feedback structure, needs at least two. So cross coupled transistors would be the straightforward way.
By nature of the involved transistors, the negative resistance won't be a pure real impedance, and due to parasitic elements (e.g. bond wires), you can hardly present a negative resistance with GHz bandwidth off-chip.
Hi Dear LvW
As i can remember about one or two years ago there was a discussion regarding the same issue here , and i remember FvM answered this as using oscillators i told that idea , based on what i saw in that time . so if i'm wrong you correct me please .
Yours Sincerely
Goldsmith
Hi Dear FvM
What if a Gali-5 be used as a main amplifier which can be used as a wide band amplifier and then adding a positive feedback path ?
Best Regards
Goldsmith
Tunnel diodes and Gunn diodes have a negative resistance characteristic and work at microwave frequencies.
Is there any reason you specifically want a CMOS circuit?
