lunren
Member level 4
Hi,all,
We are going to design a gate driver for LCD. We have two positive power supplies, negative power supply and ground. The inputs are normal digital signals, the output is level shifted signal(higher voltage). Now the problem is which one should the substrate be connected to, negative power supply or ground?
