needed small, cheaper and good humidity sensor
dpechman
Full Member level 1
Brazilzil
humidity sensor sample
hello,
please, im needing a sugest of relative humidity sensor with 0-5V output or another kind like this...must be small
thanks,
Daniel
small humidity sensor
Hi
Check DS18S20 from dallas (Maxim) and SHT11 from sensirion or the lm35 circuits from national. The two first ones are discussed in other posts in this forum.
Good luck
humidity sensor samples
very interesting this sht11, but this lm35 are not just a temperature sensor?
humidity sensor free sample
Hi Daniel
We use a Galtec humidity sensor - it simulates PT100, and it's not exactly cheap, but maybe they do something more suitable for you.
Might be a starting point
Cheers
Pete
sht11 - digital humidity sensor pic16f628
Hi Pete,
what im looking for is something exactly like the SHT11, but i dont know his price yet...im projecting an data logger with temperature, humidity and pressure, but have to be small and the most cheaper possible.
philips h1 humidity
Try h--p://w-w.humirel.com/products.html
Ther hace raw sensor and modules.
They are very nice. I have watched such sensors for 20 years.
humidity sensor wood
the sht11 is nice. i use it for one year.
it costs around $16 for one piece, directly by farnell
but you can get a free sample on the sensirion site
https://www.sensirion.com
the *bad* thing is that this sensor is digital and you must connect it to a microcontroler, you cannot use it with logic gates or multivibrators.
galtec temp humidity
:) Hi there,
I do not consider that connection to mcu is such a bad thing, per se. You can use the mcu to calculate the dew point (using temperature and humidity information from the SHT11).
Well that's my two cents.
0-5v humidity sensor curve
The very very low cost humidity sensor will be a small piece of wood (or celuloid) :) . Read the attach article how you compute the air RH base on wood resistance. Even if I think that you will not use this "sensor" it's interesting from the theoretical point of view.
humidity sensor philips shematic diagram
hello,
in a project for a datalogger we used a honeywell humidity sensor (HIH 3610). We made good experiences with it. Look at:
h**p://content.honeywell.com/sensing/prodinfo/humiditymoisture
good luck...
humidity sensors samples request
Dspnut said:
:) Hi there,
well, I say *bad* because he wants a simple humidity sensor. After I read that he also want to have pressure sensor, so the microcontroler is an almost obliged way...
but by "simple" humidity sensor, the phillips pseudos capacity, inclused in a multivibrator, are the simplest schematics, and analog ones for those who dont want to make digital measures !
well, my two cents too !
i want to build a humidity sensor
Hi!
sht-11 and sht-71 is very good devices.You can order samples from sensirion.If you request samples, don't forget to request sample codes for popular mcu's.I requested code for pic16f877 and if somebody interests i can send it via e-mail.
Analyzer.
humidity sensor sample maxim
I'd like to receive a circuit diagram for interface PIC16F877 (microcontroller) with SHT11 and code CCS-PIC16F877 ? Or Serial Port PC ?
I need routines for reading the SHT11 sensor (humidity and temperature) with a PIC16F877 or PIC16F628 microcontroller.
Can you help me ?
Thanks
Regards,
sylvia_karla@yahoo.com.br
You Wrote
Hi!
sht-11 and sht-71 is very good devices.You can order samples from sensirion.If you request samples, don't forget to request sample codes for popular mcu's. I requested code for pic16f877 and if somebody interests i can send it via e-mail.
Analyzer.
cheapest humidity sensor
H1 humidity sensor. but this sensor's output is a capacitance between 112pF (at 10% RH) and 143pF (90% RH) Its curve is not linear so we'll use a simple table to convert the A/D reading to the correct RH-value. Capacitance to frequency conversion is done with a simple 555 timing circuit. This frequency is fed to the PIC's T1_CLK
sht11 free sample
Hi, analizer :D!!!
I interested in the pic16f877 code. Please send me!!
Thanks in advance!!
honeywell humidity sensor samples
ANALIZER!!!!!
I need the code for pic16f877 for shtxx!!
please send it me!
thanks!!!
