Needed: Higher Engineering Maths. by Grewal
yaseen
Newbie level 3
Newbie level 3
higher engineering mathematics grewal
Higher Engineering Mathematics by Dr. B. S. Grewal needed.
Can any one plaese upload the book?
higher engineering mathematics by grewal
I have the 38th edition in book, but how to upload.
Pls give me some ideas....
higher engineering mathematics by b.s.grewal
Go to http://rapidshare.de/ and upload the file(s) from your disk, and the site returns to you the links for files.
I said i have the book not the e-book.
So what to do now.
How am I to scan some 1500 pages so quickly and post it on the net.
bs grewal ebook
This is what you need:
1.- a scanner
2.- ScanToPDF
3.- PDFCombine
Notes:
1.- Try not to set a very high resolution on your scanning. Otherwise your scanned files will be too heavy and the uploading would be slow, unless yuo have a fast connection. Make a previuos test using different resolutions checking the quality and the size of the resulting document.
2.- ScanToPDF lets you scan documents directly to the PDF format. As I am sure you will not scan the whole book in just one time but several ones, then you will have several pdfs files in the end.
3.- So, you vill have to use PDFCombine to join the several parts into jus one pdf file corresponding to the whole book.
4.- Once you have the ebook in pdf format, go to rapidshare and upload it. Remember that rapidshare has a limit of 100 Megabytes for uploading, so if your file is larger than that, you will have to use Winrar to compress it and split it in parts less than that limit.
Good Luck.
Bye.
