Needed Help on Simple Equivalent Circuit Model from HFSS into Schematic
frodonet
Member level 2
Member level 2
Hi Guys,
I have been having some issue in making my antenna design into a equivalent circuit model. I have managed to export it from HFSS into a library PSPICE file.
After I exported it, i use this PSPICE AD lite edition to open the library file. At first i saved it into a .cir file and then i try to run the simulation but then it says devices are not found. I really dont have any idea on pspice. I have attached the export pspice lib file as well.
Another thing, how can i transform this into a schematic file?
View attachment bd26.rar
Can anyone help me?:sad:
You should not save this file as .cir file. You need to use this as .lib file or model file. You need to connect proper input & load to this subckt model. That would be complete circuit and it should work.
Example
V1 1 0 SIN 0 1 1Meg 0 0 0
R1 2 0 50
X1 1 2 1233
.tran 1n 100n
.probe
.lib bd26.lib
.end
In this example I have used you subcircuit model 1233 and connected an Sin source of 1V 1megHZ at it's input and terminated the model (or load) of 50 Ohm
This should work.
However I guess, this circuit may be too large for Lite edition. PSpice lite may not support this big circuit.
