suhas_shiv
Full Member level 2
I need to calculate R0 for 0.25um TSMC. I am taking a value of 0.1 for lambda. Is it the right value? Thanks
suhas_shiv said:Thanks Guys.
So if I am using the design length as 1um with 0.25um technology, so the lambda is 0.5, right? Appreciate the response.
suhas_shiv said:The lambda I am talking about here is the channel length modulation parameter. Its units is 1/V. Its inversely proportional to channel length. So what would its value be for 1um length (using 0.25um TSMC technology)?
I think I read somewhere that the value for this lambda is around 0.09-0.1 for 0.25um(when using minimum length). If this value is correct, would it be the same for 1um length using 0.25um technology or would it be slightly different?
Thanks to everyone for helping me out.
