[PIC] Need urgent help in switch case in this menu code.
Rickooo
Member level 3
Member level 3
Hello, I am working on nmenu code and I want to do switching ON the LED by using push button which then select the desired menu on OLED SSD1306 . There are three button, up down and select which is connected to b5, b6, b7 pin and I want output at bo, b1, b2. Please look to the image added below the text. Now how do I switch ON the led when I select the desired menu on OLED and that time other 2 led is off.
I have used this switch logic;
void discharging_USB() {
        SSD1306_ClearDisplay();
        cursor(starting_row);
        SSD1306_GotoXY(starting_col, starting_row);
        SSD1306_PutC("1. 5V 1A");
        delay_ms(10);
        start_row = starting_row;
        start_row +=1;
        SSD1306_GotoXY(starting_col, start_row);
        SSD1306_PutC("2. 5V 2A");
        delay_ms(10);
        start_row +=1;
        SSD1306_PutC("3. 5V 3A");
        delay_ms(10);
        start_row +=1;
        SSD1306_PutC("4. Back");
        delay_ms(100);
       if (m2==1 && row_Ind == 1 && button_select==0){
       m2++;
        if( m2==2 && row_Ind ==1)
            output_low(PIN_B0);
            output_low(PIN_B1);
            output_high(PIN_B2);
            button_select==1;
           else if (m2==2 && row_Ind ==2){
            output_high(PIN_B0);
            output_low(PIN_B1);
            output_low(PIN_B2);
            button_select==1;
            else if (m2==3 && row_Ind ==3){
            output_low(PIN_B1);
            output_low(PIN_B2);
            button_select==1;
           else
            output_low(PIN_B0);
            output_low(PIN_B1);
            button_select==1;
I don't know how do I frame this loop.
m2==1 mean that there is menu which is considered as m2==1
for eg:
1. ABC
2. DEF
3. GHI
and when m2==2 mean that when we go to sub menu of 1. ABC 2. DEF 3. GHI
and I wanna select sub menu of ABC, which is
1. 5V 1A
2. 5V 2A
3. 5V 3A
4. Back
If I just go with m2==2 then program get confuse with which menu it will go with, either ABC, DEF or GHI
Guide me what syntax do I use in it..
Awaiting your response.
Here is the image link:
http://postimg.cc/68js4q64
It is your choice but I find the code confusing, I would do it differently:
Instead of writing everything "in-line", put the text and the output commands into an array. This lets you select them by one index instead of having to select them all each time. Then the selection process becomes a simple process of adding or subtracting from the index number.
The image link takes me to a home improvement web site! Please post images directly on Edaboard if possible.
Brian.
