seymour
Newbie level 1
I am interfacing a vending-machine control board with a GSM module (a Sony-Ericsson GT47/48). The serial interfaces are RS232 (for the control-board) and TTL (for the module)
I have a MAX232 in the middle which works perfectly when tested between a PC and the module BUT it works intermittenly with the control-board, meannig that some times the control-board "hears" the module and sometimes not (on average 50-50), even though while sniffing the bus with an external PC the data looks clean.
The MAX232 has a voltage swing between 8.5v and -8.5v, which is quite inside the standard.
My Hypothesis is that the control-board expects 12v to -12v on the T1OUT. I tried using a 1458 opamp as a simple open loop non-inverting comparator to achieve that, but even though it improves the system it is far from a costumer grade product and it forces me to use a ±12v power supply.
I tested with several MAX232 ICs. with same results and I know the control-board is working OK.
Any idea on how to solve this problem?
Thanks in advance,
Seymour
Thanks in advance,
Seymour
