ZacMan
G'day all.
I've got an idea for a wee project involving detecting how much current is flowing through an automotive ignition coil. When setting these up, you can vary the amount of time the system allows current to flow through the coil before it is switched off and the coil provides a spark at the sparkplug, this time is call dwell. During dwell, the current flowing in the coil builds up in a fairly linear fashion.
Currently for testing this I put a 10W 0.1R shunt resistor in-line with the power wire to the ignition coil and measure the voltage drop across it with an oscilloscope. I stumbled upon the ACS712 current sensing IC's recently, and reckon they'd be a nicer way to go, as they don't create a loss in the circuit.
I'd like to create a simple tool which goes in-line with the power wires feeding the ignition coils, and provides a visual indication that a suitable current level is being reached, and this the dwell time is long enough. My idea is to send the ignition coil power through an ACS712 Hall effect current sensing IC, and feed the output voltage from this chip into an op-amp comparator, which has a setpoint defined by a voltage divider. When this op-amp detects a higher voltage output from the ACS712 than the setpoint, it can turn on an LED.
How would I get the LED to stay on though? As these instances of the ACS712 output voltage being higher than the setpoint voltage will be very very brief. I had thought of using a mircoprocessor for the job, but its going to be a very electrically noisy area with lots of amps of current flying around, being sent into magnetic devices...
I'd be very very interested in hearing any experiences had with the ACS712 current sensing IC's, or just current level detection in general.
Cheers all.
Cheers all.
