I ones needed such a Transistor. At that time I figured out that it is not the j6812. Probably it is this one.
J6812=FJAF6812 from Fairchild.
NPN Triple Diffused Planar Silicon Transistor
Absolute Maximum Ratings TC=25°C unless otherwise noted
* Pulse Test: PW=300µs, duty Cycle=2% Pulsed
Symbol Parameter Rating Units
VCBO Collector-Base Voltage 1500 V
VCEO Collector-Emitter Voltage 750 V
VEBO Emitter-Base Voltage 6 V
IC Collector Current (DC) 12 A
ICP* Collector Current (Pulse) 24 A
PC Collector Dissipation 60 W
TJ Junction Temperature 150 °C
TSTG Storage Temperature -55 ~ 150 °C
High Voltage Color Display Horizontal
Deflection Output
• High Collector-Base Breakdown Voltage : BVCBO = 1500V
• High Switching Speed : tF(typ.) =0.1µs
• For Color Monitor
Replacements: 2SC4890, 2SC5411, BU4525AX, and NTE2365 (insulator -ral)
or
2SC5270,BU2527A,2SC4890,2SC5387(AS)
