Need the connections of a washing machine having timer , motor etc ?
dineshdeshmuk
Full Member level 5
Full Member level 5
How to wire all these together so that the washing machine start to run safely and smoothly , don't have the connection diagram its lost
How many phase?You need contactor,timer to connect the machine .The wiring diagram is simple.
only single phase .......
couldn't understand the wires from the wire colors blue , brown , green , white , red etc
Most western machine machines have a drum motor that runs in at least two modes :- washing, slowly backwards and forwards, Spin cycle :- limited torque high speed. There is also a low power motor on the pump, to pump the water from the machine. The machine will also have solenoid valves to admit water into it and to use the detergent out of the dispenser, level detectors to limit the water level in the drum. An electric element and thermostat to heat the water. And an interlock on the door to stop it being opened while the machine is full of water.
Now what are you intending to do?
Frank
I want to know the connections of a single phase washing machine ........ connection diagram or circuit schematic .....
Of timer , Motor and the other components which are present inside a washing machine
because i changed the timer and i didn't note the connections and hence i have got a big problem about how to get the washing machine into the running status .........
Can you provide me any of the connection wiring diagram ? of any brand of any model ..........
no wiring diagram , no connection diagram no schematics ?????
