Need Synp!ify 7.2 linux license
danno
Junior Member level 3
synplify linux license
Can anyone help me?
Thanks,
-danno
Need too
If somebody have a license for it, please give me too!
THX a lot, Phytex
I have confirmed that the Windows version 7.1 license will
work with the Windows version 7.2 Synp!ify Pro.
They must have changed something in the 7.2 Linux version
because a Linux 7.1 license will not work...
Yes, I do encounter this problem as well.. the waining messege is that the checkout license cannot authorize the platform of LINUX. How to fix it ?
In addition, HDS of Mentor seems to have the same problem as that of Synplify.
Anybody can offer any suggestion?
Joyee
linux license problem
I have the same problem. Synplify gets a wrong HOSTID under linux.
Can anyone help me with this????
Thanx,
stUch
What do you mean "Synplify gets a wrong host id"?
If u generated your lic, then use the hostid that Synp returns you ... if that's the reason.
I meet the same problem under Linux.But the same license file work very good under Windows 2000.
Synplify gets only the last 2 digits of the MAC address, e.g. "D0", and even if I change the license to have that HOSTID, synplify wont accept it.
make a floating license and running on windows platform
But if use a floating license,need two PC.
Thanks!But what is the reason?Synplify use a different encrypt method under linux?
Not sure, but I think they updated the encryption
seed for Linux..
you means with it synplify running well on linux?
Still does not work
It does not work under Linux, I tried and I still get the same result. see the jpeg file.
hostid
I have the same problem,if you look in the terminal window it keeps saying invalid host.I dont know what's wrong with it :(
See ya
Politicanate
