mjansi86
Newbie level 2
Hi ,
I was trying to run Smoke analysis for the rfamp sample circuit. But when I run the transient simulation, PSPICE netlist shows some warnings like “PSPICE template is not available” (Attached the snapshot – rfamp_netlist warnings).
Also transient simulation captures only the input signals V(in) and abs(V(in)) and I couldn’t even probe the output signals(Snapshot attached – rfamp_simulation output)
If I run the smoke analysis, it is displaying as “Results not found. Select a transient profile and run Smoke analysis” (Snapshot attached – rfamp_smoke analysis output))
Also I tried to simulate a simple voltage divider circuit by taking the components from PSPICE_ELEM library but ended up with the same netlisting error, “PSPICE template is not available” and additionally : “Your design does not contain a Ground (0) net” eventhough a ground net is added(Snapshot attached - Voltage divider_Netlist warnings)
There was a simulation error stating “There are no devices in this circuit”(Snapshot attached - Voltage divider_Simulation error)
Please let me know where the issue is?
Awaiting for your response..
Thanks,
Jansi Rani. M
Thanks,
Jansi Rani. M
