tricomp
Newbie level 6
Power-Over-LAN
Hi All,
Does anybody here have any real hands-on experience that they are willing to share, regarding power-supplying for example a WiFi Access-Point over the spare conductors in a CAT5 cable?
The reason for doing this would of course be to physically locate the access-point very close to the external antenna, thereby cutting cableloss to neglible. Not having to worry about mains supply in a remote spot would simplify the installation enormously. However, the Access-points I have on hand made by TRENDnet are supplied by an external switch-mode power supply labelled 5Volt/2Amp. This indicates that all voltage regulation is done in the SMPS and probably none in the Access-point. If that's the case even a short distance of CAT5 would prove disastrous to the power regulation.
So, I imagine an un-regulated higher-voltage Power-supply at the feeding point of the CAT5 and a local 5V/2A stabilizing circuit near the Access-point would do the trick. Not a perfect solution but much preferable to extended RF and/or Mains cabling.
Your comments, Gent's
/tricomp
Hi All,
/tricomp
