Need Suggestion for an IR Sensor with Bluetooth Connectivity
EltonBrasil
Junior Member level 3
Columbus, Ohio, USA
Hi Everyone,
I have a project in which I need to measure the temperature and send the data through bluetooth connectivity. So, somebody can suggest a smart sensor in which it can measure the temperature (with good accuracy) through IR and that there is bluetooth connectivity?
Many thanks in advance.
https://www.micro-epsilon.com/temperature-sensors/
the above link has sensors from which you can choose an IR sensor. As for the Bluetooth connectivity, you can attach an HM-10 or HC-05 Bluetooth module to the IR part. I don't know if there is an IR sensor which has built-in Bluetooth connectivity.
i think you may have to use DHT11 or DS18b20 temperature sensor and bluetooth HC-05 or HC-06
with arduino or any other microcontroller with built in ADC channel. program mcu for taking temperature reading
and send it through bluetooth via serial commands . but you must paire the Tx bluetooth with Rx bluetooth
first. what receiver device having bluetooth are you using?
