Need Spice code for adders and multipliers
amaraneni
Newbie level 2
Newbie level 2
i need spice code for adders and multipliers (low power)
spice code for digital multiplier
Are you looking for spice models of actual multiplier circuits -- for example ones from Analog Devices. I think those are readily available at the AD web site.
Or maybe you are looking for a transistor level implementation of these devices? Can you get away with using behavioral models -- then adders and multipliers would be real easy by using the B sources which are available on most flavors of spice.
Can you give some more information and I am sure someone can point you in the right direction.
Best regards,
v_c
spice nand gate code
i want spice code for 8(or)16bit adders &multipliers
send immeadiatly
and gate pspice code
Here is a 4 bit adder simulation. I think you should be able to modify it for 8-bits -- just implement your logic using the supplied subcircuits for the NAND.
     ADDER - 4 BIT ALL-NAND-GATE BINARY ADDER
     *** SUBCIRCUIT DEFINITIONS
     .SUBCKT NAND 1 2 3 4
     *   NODES:  INPUT(2), OUTPUT, VCC
     Q1        9  5  1 QMOD
     D1CLAMP   0  1    DMOD
     Q2        9  5  2 QMOD
     D2CLAMP   0  2    DMOD
     RB        4  5    4K
     R1        4  6    1.6K
     Q3        6  9  8 QMOD
     R2        8  0    1K
     RC        4  7    130
     Q4        7  6 10 QMOD
     DVBEDROP 10  3    DMOD
     Q5        3  8  0 QMOD
     .ENDS NAND
     .SUBCKT ONEBIT 1 2 3 4 5 6
     *   NODES:  INPUT(2), CARRY-IN, OUTPUT, CARRY-OUT, VCC
     X1   1  2  7  6   NAND
     X2   1  7  8  6   NAND
     X3   2  7  9  6   NAND
     X4   8  9 10  6   NAND
     X5   3 10 11  6   NAND
     X6   3 11 12  6   NAND
     X7  10 11 13  6   NAND
     X8  12 13  4  6   NAND
     X9  11  7  5  6   NAND
     .ENDS ONEBIT
     .SUBCKT TWOBIT 1 2 3 4 5 6 7 8 9
     *   NODES:  INPUT - BIT0(2) / BIT1(2), OUTPUT - BIT0 / BIT1,
     *           CARRY-IN, CARRY-OUT, VCC
     X1   1  2  7  5 10  9   ONEBIT
     X2   3  4 10  6  8  9   ONEBIT
     .ENDS TWOBIT
     .SUBCKT FOURBIT 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
     *   NODES:  INPUT - BIT0(2) / BIT1(2) / BIT2(2) / BIT3(2),
     *           OUTPUT - BIT0 / BIT1 / BIT2 / BIT3, CARRY-IN, CARRY-OUT, VCC
     X1   1  2  3  4  9 10 13 16 15   TWOBIT
     X2   5  6  7  8 11 12 16 14 15   TWOBIT
     .ENDS FOURBIT
     *** DEFINE NOMINAL CIRCUIT
     .MODEL DMOD D
     .MODEL QMOD NPN(BF=75 RB=100 CJE=1PF CJC=3PF)
     VCC   99  0   DC 5V
     VIN1A  1  0   PULSE(0 3 0 10NS 10NS   10NS   50NS)
     VIN1B  2  0   PULSE(0 3 0 10NS 10NS   20NS  100NS)
     VIN2A  3  0   PULSE(0 3 0 10NS 10NS   40NS  200NS)
     VIN2B  4  0   PULSE(0 3 0 10NS 10NS   80NS  400NS)
     VIN3A  5  0   PULSE(0 3 0 10NS 10NS  160NS  800NS)
     VIN3B  6  0   PULSE(0 3 0 10NS 10NS  320NS 1600NS)
     VIN4A  7  0   PULSE(0 3 0 10NS 10NS  640NS 3200NS)
     VIN4B  8  0   PULSE(0 3 0 10NS 10NS 1280NS 6400NS)
     X1     1  2  3  4  5  6  7  8  9 10 11 12  0 13 99 FOURBIT
     RBIT0  9  0   1K
     RBIT1 10  0   1K
     RBIT2 11  0   1K
     RBIT3 12  0   1K
     RCOUT 13  0   1K
     *** (FOR THOSE WITH MONEY (AND MEMORY) TO BURN)
     .TRAN 1NS 6400NS
     .END
