software rtc are tricky the mellenium bug proves this one
so you need too use timers and wasted timing cycles get added back on again too keep actual time
the timer events drive the actual count and any correction is added
before the time is called and the dat used or stored passed or updated
too do this you use timer based interupts
i found a page of source code onthe net with lots of projects
