TheBorgli
Newbie level 3
Hey guys, I have a question when it comes to powering an actuator for my boats clutch.
This is going to be kind of hard to explain, but I'll do my best. Let me know if there is anything that is unclear.
I have a boat where I want the clutch to be operated by an actuator and a push button.
The actuator is a linear 12v, 2 wires. It does not extend and retract all the way with a push of a button, but requires the button to be held down until it reaches the desired position.
It also does not reach its max extension before the clutch is completely depressed, so I need to stop it when the clutch is all the way in or out. Otherwise it just keeps working. (it actually keeps working until the button is released even if it is fully extended)
With that bit of "backstory" out of the way, here is what I want it to do:
I want to have one button on my dash that will have a built in light to show when the clutch is pressed. I would like that same button to release the clutch and the light to go out when it does (so that I know what the clutch is doing).
I figure that I need some kind of reversing contactor with a normally open loop and a NC switch at either end of the actuators travel to stop it?
It would be great if someone could draw up a diagram or atleast list the parts I am going to need.
I am really handy and a pretty good shade tree mechanic, but this stuff gets me so confused
Thanks!
Thanks!
