Need Solution for voltage divider bias with two source
satiz
Member level 5
Member level 5
Hi there,
Can anyone help me to find Vout for the attached circuit?
How to solve this?
hint:
* interchange [50 Ohms] with [750V]
* then combine [50 Ohms] with [5 milliOhms]
Klaus
Reactions: satiz
    satiz
The resistor value is 3Mega ohm
use superposition
the voltage at Vout is the sum of voltages at Vout due to the two sources
short source 1 and find Vout from source 2 = Vout from 2
short source 2 and find vout from source 1 = Vout from 1
Vout total = Vout from 2 + Vout from 1
Reactions: satiz
    satiz
if my guess is correct, Vout is approximatly 2.5V to 5V.
